whats the widest 19 you can fit on a 4th gen camaro?
Heres a Camaro with OEM 40mm offset Fronts /59 mm offset Rear wheels and the OEM tires sizes . 325/30-19 and 275/35-18 . This car was hammer tubed with the pinion snubbed cut off . The OEM offsets look SOOO much better on the 4th gens as their not sitting so far in the fender well . Most of the replica Z06 wheels use the stock C6 wheel offsets 56mm front/78 or 79 rear which is why most of them tuck in so much .
I'll be posting pics of the finished product for sure. But until then I'll post pics of the wheels and tires. Look for the finished product early-mid February.
Attachment 276395
Attachment 276396
Attachment 276397
Attachment 276395
Attachment 276396
Attachment 276397
Attachment 276395
Attachment 276396
Attachment 276397
Attachment 276395
Attachment 276396
Attachment 276397
[QUOTE=LT4vert;14421789]Heres a Camaro with OEM 40mm offset Fronts /59 mm offset Rear wheels and the OEM tires sizes . 325/30-19 and 275/35-18 . This car was hammer tubed with the pinion snubbed cut off . The OEM offsets look SOOO much better on the 4th gens as their not sitting so far in the fender well . Most of the replica Z06 wheels use the stock C6 wheel offsets 56mm front/78 or 79 rear which is why most of them tuck in so much .
[QUOTE]
love your car and the set up, i saw it in GM hi tech, im running c5 chrome 19x11's rear with 315's and 19x9.5 front with 275 on my ss. i have a 10mm spacer since they arent OEM but ill be putting on is march/april with a hammer mini tub also!
Austin* your car is going to look great, idk what wheel im going to do on my ws.6 yet, cant wait to see it done!
[QUOTE]
