not connecting CAGS and reverse lockout?
Old 01-29-2011, 05:24 AM
importkiller_SS's Avatar
Default not connecting CAGS and reverse lockout?
I just recently swapped from an A4 to M6 and i was wondering if i do not connect to the CAGS actuator on the trans will it affect anything? same thing with the reverse lockout if i dont connect it?
Thanks
Old 01-29-2011, 08:04 AM
samdogmx's Avatar
you might get a check engine light. The only thing connected to my T56 is the VSS
Old 01-29-2011, 09:27 AM
calhoon's Avatar
You won't miss the skip shift much.
calhoon's Avatar
The reverse shift effort will be high but do-able.
Old 01-29-2011, 10:19 AM
therealcreeper's Avatar
yep I ran with no reverse lockout on my swap for a while, just takes two hands to push it over. I got lazy and just hooked it up to my reverse light switch so I can put it in reverse as long as I'm on the brake.
Old 01-29-2011, 11:42 AM
samdogmx's Avatar
I removed the whole soloniod & made a block off plate.
Old 01-29-2011, 09:56 PM
RedRallyeZ's Avatar
Never hooked up CAGS, i wired reverse lockout to my back-up lights, it was just too big of a pain to have to use two hands to put it in reverse.
Old 01-30-2011, 01:41 AM
good, i was thinking by not hooking up the solenoids it would interfere and not let me shift into certain gears.
Thanks for the info
Old 01-30-2011, 06:50 AM
89 formula350's Avatar
on my old car I never hooked them up. I took the solenoid out and then put a bigger spring under the plunger. used some RTV in the hole where the solenoid was and tapped a cap in place. this gave me a little more effort going into reverse so I couldn't just slide in on the hwy.
Old 01-30-2011, 09:27 AM
Save the manuals!
wssix99's Avatar
The reverse lockout is there to make sure you don't wreck the car or explode the transmission by accidentally putting the car in to reverse instead of 5th while you are at speed. Its a good thing to have hooked up and working.
Old 01-30-2011, 10:37 AM
agreed... i guess i should not let a broken connector on the Reverse lockout stop me from hooking it up
Old 01-30-2011, 10:55 AM
Save the manuals!
wssix99's Avatar
What's broken? The connector on the solenoid or the wire that plugs in to it. If its the later, you can get a new connector body.
Old 01-30-2011, 01:55 PM
Spartan7's Avatar
Seriously? Not wiring up reverse lockout? It takes 5 minutes, if you know which wires to splice into.
Old 01-30-2011, 02:02 PM
its the connector on the solenoid...
i understand it is really simple to hook up... which i am not going to use the "broken connector" as an excuse to not hook it up... im defiantly going to hook it up now.
i suppose i have to buy a whole new solenoid tho...
Old 01-30-2011, 05:17 PM
Save the manuals!
wssix99's Avatar
Depends. Can you post a pic? If a piece of the connector is broken, do you still have it?
Old 01-30-2011, 09:36 PM
ill have to get a picture of it tomorrow when im under there...
Quick Reply: not connecting CAGS and reverse lockout?
