Do I need tuning when swapping injectors?
Old 02-11-2004, 08:37 PM
fastGBcamaro's Avatar
Default Do I need tuning when swapping injectors?
After my cam swap I am expecting to be putting down 400- 410rwhp. Being that my car is a 2000 and it is said that the injectors will be flowing at 100% at about 420rwhp, I was thinking about changing the injectors to be on the safe side. Also I might add a shot of N20 in the near future so I will def. need injectors and an intank fuel pump. But will I need to get the car tuned after either of these additions or will the computer recognize the increase in fuel and control it. If I do need tuning, would a custom tune from my predator via James at RWTD be sufficient?
Old 02-12-2004, 10:00 AM
NoGo's Avatar
You will need tuning if you go larger than the 01, 02 injectors. I would advise some 30lbs if you are going to be running the giggle gas.
Predator should be able to change injectors sizes.
Good Luck
