custom 5th gear in T5
Old 01-30-2011, 10:12 PM
battousai's Avatar
Default custom 5th gear in T5
I have a T-5, and was wondering if it's possible to get a custom 5th gear, so that i could have 4.10's in the back, and be able to cruise on the highway with low RPM's... is it possible
Old 02-01-2011, 08:07 PM
battousai's Avatar
anyone? mostly sponsors please.
Old 02-02-2011, 08:09 AM
calhoon's Avatar
You might get a better response if gave a range of ratios you want. But to answer the original Q: You can make a custom 5th ratio. It would take both drive and driven gear manufacture . aiat would be limited by what you could fit into the castings and by the driven gear cross-section. That is ,the gear is pressed on the mainshaft so it would have to have enough"meat" to assemble without distorting.
Old 02-02-2011, 11:24 AM
jmd
jmd's Avatar
.59 is do-able, depending on what gearset you have currently.
There were a LOT of different T5 boxes made with different gear tooth counts.
Old 02-02-2011, 11:53 AM
thesource's Avatar
With a 2.95 ratio gear kit, you can get down in the .59 area.
Quick Reply: custom 5th gear in T5
