3rd gen Drive shaft.
Old 02-03-2011, 04:47 PM
Young LS1's Avatar
Default 3rd gen Drive shaft.
I got my engine and trans together but before i put it in, i need to find out if anybody knows the measurement for a drive shaft or can my original shaft fit?
If it helps i still have the stock rear end.
Old 02-03-2011, 05:06 PM
xtreme2001's Avatar
if you are installing an ls engine and 4l60e trans it should be the same driveshaft,unless you are moving the engine back.
Old 02-04-2011, 10:10 AM
Isolde's Avatar
Pocket may correct me, but as I understand it, those red mounts sold by Hawks, Spohn, and maybe BMR do move it all back an inch.
If you have the car itself on stands, you may be able to get the stock driveshaft in, BUT it'll bottom out when you let the car down.
Now, since I used to build driveshafts for a living, for a couple of years, I do know the slip yoke is supposed to be about 1" from bottomed when the car is parked on it's own 4 tires.
Old 02-04-2011, 11:16 AM
Wimimc's Avatar
i think it should fit, people swap the aluminum driveshafts form LS1s into third gens quite often
Old 02-04-2011, 04:22 PM
Young LS1's Avatar
I have a 4thgen drive shaft so im going to try that first before go with the stock one.
Old 02-04-2011, 06:31 PM
Pocket's Avatar
Using the Spohn mounts or 1" setback adapter plates on SBC mounts the stock driveshaft fits perfectly
Quick Reply: 3rd gen Drive shaft.
