Anyone running this pan on a LS in a A body?
http://www.jegs.com/i/GM+Performance...12593/10002/-1
I believe it's a H3 / Colorado pan - How much (if any) does it hang below the front crossmember? Did you need to clearance the crossmember?
Thanks
LK
Thanks
LK
From what I understand it's a little deeper than the JZ Motorsports (or RetroLSX) pan I'm running. I spaced my motor perches up about 3/4" and my ground clearance is almost even with my front crossmember. I would be hesitant to run my oil pan any lower than this.
its the same in the front as the gm hot rod pan aka the h3, lh8 pan. it will hang down to far if your lowering the car. the lhx just has the shorter sump so it does not hang below the cross member. and is now going to be made by holley.
