parts needed to finish
Old 02-11-2011, 12:15 PM
am_muscl's Avatar
Default parts needed to finish
I posted this in the WANTED section and got nothing so I'm wondering if my fellow LTX guys may have some things to help me out:
So I've got a list of what I need/want in order to finish my build that I've got going.
I need:
-37lb injectors FOUND THEM (thanks to AKMAC)
-58mm throttle body WORKING ON IT NOW (thanks to ACHotrod)
-subframe connectors (boxed)Picking them up today(thanks to Badazz97t/a)
-motor mounts
I want:
-s60, 35 spline w/spool n 3.73 gears
-tubular k-member, upper n lower A-arms(last thing I'll buy)BOUGHT IT THROUGH SUMMIT
-rear shocks (Comp Engineering)Found them(ACHotrod again)
-fuel pump (Racetronix)picked it up(thanks to Smokedoutz28)
-canton oil pan (with oil pump n everything to bolt right up)GOT IT! thanks Clint
-electric waterpumpGot it!!
-stainless steel headers(even the ebay ones if they'll work)
LEMME KNOW WHAT YOU HAVE. fyi my zip is 60067 to a business for shipping as well
Update 6/3/11- I just realized I have a shitload of parts and I found a ton of things that I actually wanted! Now it's just a matter of putting it all together. I really need the motor though first because I want to just slide the motor and front suspension under the car all as one piece.
SLOWLY BUT SURELY THIS CAR WILL GET DONE!! I've literally been waiting 5 years for this opportunity and it's finally coming true!
Old 02-11-2011, 03:21 PM
am_muscl's Avatar
hopefully workin out a deal on the throttle body n possibly injectors also
still need the other things
Old 02-11-2011, 04:19 PM
qc97z's Avatar
What part of the motor mounts do you need? I have a set of factory clamshells with rubber bushings in them, still in good shape.
Old 02-11-2011, 06:34 PM
am_muscl's Avatar
I'm looking for the whole thing. I think I might actually go with brand new mounts, but I pulled the motor n i think the mounts went with the motor. Sorry I'm kinda retarded and would have to look at the car.
Also, just got a great deal on the injectors! and working on a deal with the 58mm tb.
Old 02-12-2011, 12:40 PM
AChotrod's Avatar
I have some comp shocks you just need the mounting hardware for the bottom, might also be selling my 58TB. Pretty sure I know a guy with a S60 also. I forget whats in it but I know it comes with a anti roll bar and Im pretty sure a TA for 2200-2300
Old 02-12-2011, 07:06 PM
SmokedOutZ28's Avatar
I got a fuel pump BRAND NEW Walbro 255. PM if you want it
Old 02-12-2011, 07:56 PM
96TransAmboosted's Avatar
58mm TB are over rated! 52 or 54 will do much better and idle better as well. I have a set of brand new 36lb injectors PM me
Old 02-12-2011, 08:22 PM
Rockstar
Johnny-LT1-runner's Avatar
I've got a set of stock rubber mounts and stands to bolt to the k member.
Old 02-13-2011, 10:50 PM
am_muscl's Avatar
Hey mike if you could pm me a price for the shocks and throttle body if you are gonna sell it, I'd appreciate it. I got an offer on another throttle body but haven't heard from him.
Also if you could find out about the s60 that would be great. I don't need the torque arm though as I already have one.
Old 02-14-2011, 03:53 PM
am_muscl's Avatar
so the s60 deal fell through, still looking for one. Hopefully working out a deal to get the shocks n throttle body.
If anyone has boxed subframe connectors they want to get rid of PLEASE LET ME KNOW!! Also looking for a good deal on an EWP
Old 02-14-2011, 04:42 PM
Badazz 97 TA's Avatar
i dont have the boxed but i do have my original 2pt bolt in tubular subframes sitting in the garage that i just took off. they need to be painted but there still good if you want them. $30 bucks?
Old 02-14-2011, 04:53 PM
Wicked94Z's Avatar
I have some poly motor mounts, only been on the car a few thousand miles. i could sell the stands as well, I'm going to do a motor plate on my car so it can all go.
Old 02-14-2011, 07:37 PM
lethal bird's Avatar
If he doesnt then ill take them.
Old 02-15-2011, 09:37 AM
am_muscl's Avatar
^^ I'm gonna be pickin those up probably tomorrow. I wish I knew how to put a line through things.
I got the injectors, throttle body, subframe connectors, rear shocks.
I'm gonna be trying to work out deals for the motor mounts, oil pan, and fuel pump.
So I will still need the s60, EWP, and the front tubular suspension parts (least important to me right now)
Old 02-15-2011, 10:09 AM
merim123's Avatar
LS1Tech 10 Year
Jason - I'll get the flexplate out this week, the snow melted. Also have a OBD1 timing cover that's welded for a electric WP, let me know if you're interested.
Old 02-15-2011, 10:46 AM
am_muscl's Avatar
^^ thanks I appreciate it. if you could pm me when you get it out that would be great
Old 02-16-2011, 12:32 PM
am_muscl's Avatar
I'm narrowing down the list!! This is getting exciting. Once I get everything put together I'm gonna start a build thread and try n keep on top of it. Today my goal is to clean up the engine bay and get it painted satin black.
Old 02-17-2011, 02:17 PM
am_muscl's Avatar
so I've found the fuel pump, have an inquiry in on the poly motor mounts. Now I'm in need of a good electric water pump and i REAAAAAAAAAALLY want a good deal on a s60.
Old 02-19-2011, 11:51 AM
am_muscl's Avatar
still waiting to hear back on the oil pan and the motor mounts. DOES ANYONE HAVE AN ELECTRIC WATER PUMP?!
Old 02-19-2011, 08:58 PM
Black94Z28's Avatar
I have black paint all over my hands from painting your engine bay. And had a cop follow my Camaro for a couple miles too on my way home. Hopefully we arent assembling your car again in the hotel parking lot the night before the LTx shootout! lol
Quick Reply: parts needed to finish
