Different hid harness?
My harness has just arived, but instead of being negative & positive to connect to the battery, there is just a positive & a metal atachment on the relay plus 2 grounds off the balast conectors.
Looks like this. http://www.google.co.uk/imgres?imgur...w=1280&bih=829 Does the relay attach to the negative?
Just not sure because this looks different to the other harnesses I can find.
OK I know the eyelets ground to the body, it's just on other kits I've seen there's a pigtail coming off the relay that attaches to the negative, so wasn't sure if this was the right kit.
So the metal leg on the relay can just attach anywhere it'll fit?
