do i need to bleed after install???
So I'm installing a spec. Stg 1 today and was wonder if I had to bleed the clutch. Its my first time doing it and I need to kno if I have to bleed it and how. I got everything. Balanced clutch n flywheel. Tb bering,pilot bearing, and new slave.
Kool so i tried bleeding and nothing happend the pedel still stayed down to the floor. Could i have installed it all fucked up or wat cuz i cant even get the tranny into gear. i tried at one point and just heard grinding. So should i just rent a vac and try that or is my problem alot serious.
I suggest using a mighty-vac to bleed the system to insure that all is well. In fact it isn't a bad idea to flush and refill the system when installing a new clutch. Remember, hydraulic fluid, like any fluid, needs to be replaced over time.
Having air in the system, or a slave that has not adjusted to the height of the new clutch can affect release. If the clutch can't release fully, as a result of the compression provided by the bearing, then you can experience grinding. Subsequently, Build, lack of bleeding can lead to a transmission that grinds. Let me know if you guys have any further questions. Thanks,
