19 x 10 ZR1 Corvette Wheels _1998 Trans Am
Old 02-14-2011, 05:16 PM
allantransAm1998's Avatar
Default 19 x 10 ZR1 Corvette Wheels _1998 Trans Am
Can I fit 4 19x10" ZR1 Corvette wheels on all four corners of my 98 trans am?
I read on another thread(https://ls1tech.com/forums/wheels-ti...ay-around.html) that I have to get a 1.25" Spacer/Adapter for it to fit. I know they'll fit the rear but I don't know about the front.
Old 02-14-2011, 10:37 PM
LT4vert's Avatar
You will not need a spacer for the ZR1 19x10 . The offsets for the ZR1/Z06 wheels and the regular C6 wheels are VERY different . The 19x10 09-11 ZR1 rim has a 40mm offset . You need the spacers with the OEM reguar C6 19x10's because the offset is 79mm which would tuck the rim in the fender more than stock . As compared to an OEM WS6 or SS rim, with the OEM 19x10 ZR1 wheels on a 4th gen ...you would lose 3mm inner clearence and the wheel would stick out 23mm farther than stock.
Here is a good offset calculator
http://www.1010tires.com/wheeloffsetcalculator.asp
ZR1
19x10 40mm offset / 20x12 59mm offset
Z06/GS
18x9.5 40mm offset/ 19x12 59mm offset
C6
18x8.5 56mm offset / 19x10 79mm offset
F-car
17x9 50mm offset
16x8 55mm offset
Old 02-16-2011, 03:00 PM
Default Thanks
Thank you!
Old 02-16-2011, 03:13 PM
Default Replica ZR1 Wheels not OEM
I'm sorry the wheels I'm interested in are Replica ZR1 Wheels not OEM. On this Store Website(http://www.corvetteguys.com/19-inch-...eels-rims.html) it has a 19x10 with 56mm offset and a 19x10 with 79mm offset.Will the 56mm offset Wheel fit all 4 corners of my 98 TA?
Old 02-16-2011, 03:35 PM
6spdchevy's Avatar
Location: Oklahoma City, OK/North Long Beach/Paramount, CA
yes sir
Old 02-16-2011, 04:31 PM
SHORTZ A KILLA's Avatar
Hi-Check out the FAQ Sticky thread in wheel section -it has all offset sizes for different wheel diameters and tire widths good reference guide
Quick Reply: 19 x 10 ZR1 Corvette Wheels _1998 Trans Am
