What ARP Bolts for TCI Flexplate to Crank
Old 02-14-2011, 07:09 PM
willizm's Avatar
Default What ARP Bolts for TCI Flexplate to Crank
Hi all, I've been searching and can't find a definitive answer on which bolts I should get for the SFI TCI flexplate to crankshaft. Block is a forged bottom end ls1 with stock crankshaft and built 4l60e from flt. I'm getting this plate from Chris from Circle-D with my new converter.
I've found the following:
ARP 330-2802
http://www.ws6project.com/user_stor/...oducts_id=1373
Will those work?
Old 02-14-2011, 08:45 PM
willizm's Avatar
ARP 244-2901
I think those may be te ticket. Anyone use those and did they work well?
Old 02-14-2011, 09:04 PM
95killerz's Avatar
the ones I got for my tci plate are in fact the 2901. Haven't installed yet though
Old 02-14-2011, 10:47 PM
Heyfred's Avatar
ARP 244-2901
I just did an install using them, they were the ticket.
Old 12-03-2011, 07:47 PM
ShredSled's Avatar
so did you end up using the 244-2901?
I'm looking for a set of bolts for my flex plate right now...
from what I can tell, the 330-2802 kit is for flywheels, not flexplates? Didn't even realized they both used separate hardware to the crank until I started looking at these part numbers.
Old 12-04-2011, 01:15 AM
DietCoke's Avatar
My flexplate came with bolts.
Old 12-05-2011, 08:51 PM
Randy WS6's Avatar
I used the ARP-244-2901 with my SFI-TCI Flexplate, this what you need for your automatic
Quick Reply: What ARP Bolts for TCI Flexplate to Crank
