Halo headlight question~!!!!!!
liqour enthusiest
you can and i search i believe orangepeel on here. he did a write up about switching the color of the rings to red. i have hid's in mine and they use the stock style bulb.
^ this looks wow! i have those but they dnt look anything like yours man! to the OP yes you can make your halo red. its quite simple too. all you have to do is to follow whistler mod to open the lights, then use a 5000-10000 mcd leds of the color you like and just swap them over.
i am picking up my car saturday that has these lights on it... not a fan of them. if you are willing to wait until i get another set, would you want to buy them from me? just curious.
You can wire to an external switch pretty easily, i did it on mine, you just need to tap the two halo power and ground wires together and run them into wherever you want to mount the switch. Than just grab power off something like the cig lighter wire and ground out. I put mine on a rocker switch with red indicator light because i always forgot to turn them off.
