ls6 ecu in ls1
Old 02-16-2011, 12:17 PM
Big zman's Avatar
Default ls6 ecu in ls1
I looking at an 04 ecu for my 01 camaro. Well I wanna know what will be needed to make this work.
Old 02-16-2011, 01:17 PM
2xLS1's Avatar
Why?? 04 Vette is a 1024K DBW pcm. 01 F-body is a 512K DBC pcm.
Old 02-16-2011, 01:44 PM
Big zman's Avatar
What does the dbc mean. I'm more of a new guy on the electronics
Old 02-16-2011, 01:56 PM
2xLS1's Avatar
DBW drive by wire, electronic throttle body.
DBC drive by cable, cable throttle body.
Old 02-17-2011, 07:04 PM
TunerGuy's Avatar
You could run the 2004 GTO drive by cable OS in a 6243 PCM with minimal changes to your factory wiring, but you'd lose your dual fan speeds
I don't know of any 2004 OS's that would allow you to keep dual fans speeds, without running the BCM that goes with it
I don't see any advantage of switching to the newer PCM, since you already are running a 411
Quick Reply: ls6 ecu in ls1
