Help
Old 02-21-2011, 03:54 PM
morris's Avatar
Default Help
ok guys i have a 95 camaro with a lt1 and I was driving it today and it just quit runnning and i tried to restart it the battery was dead so i jumped it off and drove it about a mile.then the tranny would not shift right and it only let it get to about 3500 rpm and then it just died and nothing would come on so i tried to jump it off again and would not jump off so i towed the car home went and had the battery tested and they said the battery was still good.so has anyone else had this problem
Old 02-21-2011, 04:01 PM
ssteven's Avatar
You check the alternator? Is it charging?
Old 02-21-2011, 04:54 PM
LoudmouthWS6's Avatar
Like above check the alternator.
Old 02-21-2011, 05:22 PM
GreatWhiteZ28's Avatar
Problem highlighted........J/K......+3 on the Alternator
Old 02-21-2011, 06:20 PM
morris's Avatar
thats the problem there is no power to start the car cant even roll up the windows only thing it does is ding with the key is in
Old 02-21-2011, 06:30 PM
5w20's Avatar
other electrical items work?
Old 02-21-2011, 06:43 PM
morris's Avatar
nope no power inside at all headlights wont even turn on no radio no nothing
Old 02-21-2011, 06:50 PM
ex-SS-ve's Avatar
Sounds like you fried a fusible link or popped some fuses.
Old 02-21-2011, 07:10 PM
morris's Avatar
checked all the fuses and they are all good and where in the hell are the fuseable links......lol
Old 02-22-2011, 03:29 PM
morris's Avatar
Battery was all corroded and also spun a main bearing so gonna stroke it to a 383
Old 02-22-2011, 03:39 PM
SSmoked1's Avatar
How do you know you spun a bearing? Did you have your foot in it when everything quit working?
Old 02-22-2011, 04:33 PM
FireHawk178's Avatar
Not having any details other then those above, this sounds fishy. Unless spun bearings typically produce electrical/charging issues.
Old 02-22-2011, 08:42 PM
jdoyle's Avatar
my guess is that some of the popped fuses made their way into the crankcase and it locked up the rotating assembly or some battery acid mixed in with the oil and toasted said bearing.
did someone tell you that you spun a bearing or did you see it for yourself?
Old 02-22-2011, 10:54 PM
5w20's Avatar
looking at fuses doesn't mean they are good, ask regorih383 about that one lol
Old 02-22-2011, 10:55 PM
jdoyle's Avatar
what happened to him?
Old 02-22-2011, 10:57 PM
BadBird99's Avatar
Thats Great! LMAO
Old 02-22-2011, 10:58 PM
5w20's Avatar
he looked at the fuse saying it was good after i told him to replace it, which he didn't. so i started diagnosing and asked him if he had replaced it which he then had a smirk on his face. i pulled the fuse and it looked fine, but it was blown.
Old 02-22-2011, 11:00 PM
jdoyle's Avatar
gotcha
Old 02-22-2011, 11:18 PM
1c62nv's Avatar
Should be titled "Bad battery causes spun main bearing" because thats how LT1s do it. Just like "Water pump went out and totaled my distributor" Oh wait that does happen!
Old 02-23-2011, 12:41 AM
99mongooSS's Avatar
