Speedinc "budget" fuel rails. Not thrilled. [PICS]
Got this in today. ordered the Speedinc budget fuel rail system. Their product description was a little deceiving.
http://www.speedinc.com/cont.cfm?cid=C0000694
I know they're a sponsor, and I haven't been thrilled with them in the past (since 2004) so I don't mean to come off as bashing, but I'm just not impressed right now. I'll run em, but I wonder what I would get for the $30 extra.
-There's a REASON they chose not to use these rails (cheap? Leak? Defect?)
-At least put their own label around the box or repackage them.
-The box and inside was opened, missing a plug.
-If I wanted PP rail system I would have bought from them. I thought I was getting a Speedinc "House" system. (if there is such a thing)
I just expect a little more from a big place and I've prolly paid someone's yearly salary with the money I've spent there. But I know, I'm a faceless customer. Just an account number.
Hand assembled.
Hand assembled.
And do the injectors just sit in the rails? No retaining clips? Or do the rail brackets hold them in?
And what tape do I need for the connections? I know I can't use the regular white teflon tape.
And let me add one more thing... You may need larger/thicker injector o-ings... Dont worry overthere sunshine the fun is just getting started... Here some helpful advice... Buy a set of these and keep them on the shelf... https://ls1tech.com/forums/fueling-i...ng-intake.html
I just loves my shelf...
^ The FAST 102 intake came with new injector o-rings.. But I take it those are for the INTAKE side of the deal. I'll try it tmrw to see how it fits. Gotta finish up smoothing out some rough edges in the intake first. (NOT porting it.. Just smoothing) Almost done. I'll throw it together tmrw. Prolly gonna have to track down the spacers for them to work on this intake, but we'll see.
And thanks for the advice fellas.
I ordered the budget rails without the crossover, and it was missing 1 SS inlet fitting, 1/8 NPT pipe plug, and a 3/8 NPT to -8 AN 90 degree fitting. These are advertised on the web site and on the list of the kit contains these. I called Speed Inc., and they said the manufacturer does not include these fittings in the kit, even though they advertise that they do. I will never order from Speed Inc. again.
^ I found my plug in with the rest of the mounting hardware. They should really specify that these do NOT work on an LSXr intake. I called and they said that their "house" rails aren't done yet... They said they could give me a credit, but frankly, I'd rather my money back now. Come to think of it. This isn't the first time I've had an issue w them. They still owe me a set of $80 Bresslin locking header bolts from 2004, which I never received. Never got them but it's too late now.
But yeah. It seems like they just picked through what they needed and shipped the rest out.
Watch the mounting brackets on those. They are slotted (or at least were on both sets I've used) and can let the rails back off enough to leak vacuum, or, in my case, fuel. I made new brackets that are NOT slotted to fix them in place. Aside from that I've not had any issues, but I bought them bare (no AN lines). They do cut the injector o-rings easily, I buy a box every time I change injectors just because I know 1-2 of them is going to get sliced on the rails.
^ I didn't have a problem with mine. Lubed the o-ring with SeaFoam and they slid right in. The rails did have a chamfer on it. Thicker o-rings used on the intake side of the deal and they fit nice and snug.
I'm gonna drill my rail to fit the 102 mounts. Tired of dicking around with this already and I just want to get it together. It's a solid block of aluminum, it's not gonna hurt anything.
