wheel bearing problems
So i get the brakes and rotor and everything off no problem.
Then unplug that sensor and get out the 4 bolts holding the hub to the spindle. Well they were rusted together and no matter how hard i hit it with a hammer, it wouldnt budge.
I even tried holding a lighter up against it to heat it up, but i didnt have a torch. anyone have any ideas?
thanks
thanks
Save the manuals!
I had the same problem and ended up taking it to a mechanic to get off. All he had to do was tap the side of the hub from the back. (Instead of pulling.) The added leverage popped it off. You could probably also bolt up an old rotor to the hub to give even more leverage and whack the thing from behind.
