2000 chevy truck 4.8-ls2 swap
I have a friend who is looking to swap a Ls2 motor into his 2000 chevy truck. The truck has the 4.8L motor in it right now. I am looking for information into what will be needed to make this swap work. The plan is to add a 70mm air research turbo to the new motor.
I have been coming up dry with information, so any help would be appreciated.
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
The Gen IV LS2 will be alittle harder. You have to mod the harness and may even need a converter box it its an 58x crank trigger motor.
Also he need to use the 4.8L flexplate.
