Looking for new clutch
Well im in need of a new clutch and im wanting to replace the flywheel while im in there aswell, I plan on doing heads and cam here soon, going to go with the MS4 cam and LS6 2.5 heads package and need a clutch that will perform. I have right now a ram stage 3 clutch in that needs to be changed and im looking at this clutch set right here http://www.ws6project.com/user_stor/catalog/product_info.php?products_id=2919{11}1111, has anyone ever used this clutch or should i stick with ram?
I'm going with a Textralia OZ700 since I have read nothing but awesome reviews on them. With that said, I've also heard great things about monster clutches as well. I would think you'd be fine going with a monster stage 3. Seems to be about the norm for a H/C LS1 build.
Post #3
"[QUOTE=SNLPerformance; A dual friction clutch is only as strong as it's weakest link, the organic side in this case."[/QUOTE]
https://ls1tech.com/forums/manual-tr...bang-buck.html
im just looking for a clutch that will last and take a beating, while also get me home. I liked my Ram but i want a good package with a new flywheel, throw out bearing, master slave cylinder and the clutch of course, just got a aluminum driveshaft from a fellow member now just want to fix my slipping clutch problem with a bad *** clutch that will match my heads/cam that i will be doing.
