dead battery?
dead battery?
let my car sit for 3 days during a snow storm and the battery was completly toasted.. had to be jumped in order to run, continued to need to be jumped for an additional 3-4 days making that click click click noise a dead battery makes. now it makes that click click click noise(lights appear dimmer aswell) with the ignition turned awhile longer it makes the click noise then suddenly it will start to turn over as you can hear in this video then it fires up. sometimes itll die again after fireing up and ill have to do the whole procedure another 2-3 times till it runs steady, ive also noticed rpm drop off while idoling sometimes. generally it idols right at 650-700rpm then itll drop off to 300rpm and almost die. car is a 2002 ws6 with 45k miles. mild bolt-ons. any help would be appreciated.
cant figure out how to load the video.. its a video from my android phone .3gp and said its invalid..
An alternator is meant to maintain a charge, not recharge a completely dead battery. You should put a battery charger on it at 2amps for at least 6 hours or overnight.
Do you have a multimeter? If so, check the volts at the battery with the car running. If not, how many volts is your gauge on the dash showing?
Yes. Your battery is dead. Put it on a charger. Most auto part stores will charge your battery for free. It sounds like your alternator is good but you never know.
If your battery is old then it may just be time for a replacement. I had an old battery in my old truck that I ran dead. I charged it overnight at 2 amps and it fired up twice and then it was dead the third time I went to crank it. Charged it again and the same thing happened. Bought a new one then everything was fine. I had even ran mine on a desulfurization process for an entire weekend and it didn't help.
Try charging it first and see if it holds a charge.
What kind of battery, also how old is the battery, I have found that the sears batteries just suck, if you buy odyssey battery that should fix it for the life of the car.
how could it possibly be the battery tho if the car will start without being jumped??.. like i said when i crank it itll make the click click click tick noise a dead battery makes then after about 5 seconds of that happening the click goes away and the car starts to turn over(struggles doing so) but it does, then the car will start up
Loose wire? any sort of incomplete contact at the battery terminals will lead to this kind of problem ... But yea, your alternator is not going to recharge your battery after it died. You are making a potentially expensive problem (buying a new battery) even more expensive (buying a new battery and alternator).
Have you checked the connections for corrosion? My truck uses the sane style battery and connectors and it would do the same thing. I took the connectors out and cleaned them up good and that fixed the issue
