Unhook fuel line from rail
How does the fuel line unhook from the fuel rail? Does it use a tool like Ford uses for A/C lines on their cars or other unique tool?
How does the evap return line unhook from the plastic housing mounted on the intake?
I know should be simple knowledge. I tried to search the site first with no luck.
This is my first LS engine removal from a 2000 Camaro.
Thanks for the assistance!
Thank you for the response.
That's what it looked like to me. It was time for a break so I thought I would ask. I'll be back out in the shop tonight and disconnect.
I am still I am not sure how to disconnect the Evap line. It has a plastic connection to a plastic valve on the intake. Any suggestions? Does it also use the tool like the fuel line? It looks different.
