they sent me the wrong cam... should i just go with it?
Old 03-07-2011, 07:33 AM
rp0029's Avatar
Default they sent me the wrong cam... should i just go with it?
I ordered a 222/226 .566/.570 114+4 cam from comp. I was told by patrick g this cam would be good in a DD in my lq4 w/ ls3 heads/intake and a stock 4l80e pushing 3.23s in my 68 camaro. Comp shipped a 222/230 .566/.570. What difference will this cam make? Keep in mind this is for a DAILY DRIVER. Thanks!
Old 03-07-2011, 08:14 AM
newschool72's Avatar
if u are running stock LS3 heads, the added duration on the exaust side will only help. is everything else the same ie. lobe style, lobe sep., +4 on advance?
Old 03-07-2011, 08:34 AM
bozzhawg's Avatar
This is not the first time Comp has done this so don't feel singled out..... they make this mistake more often than it gets reported....lol
Bozz
Old 03-07-2011, 09:35 AM
thunderstruck507's Avatar
I would contact them about it and see what they say.
Aside from possible partial refund or some kind of swag, I would probably run it.
Old 03-07-2011, 12:04 PM
rp0029's Avatar
Will the. 572 lift be a problem on .570 ls3 springs? Comp said no problem but can I trust them?
Old 03-07-2011, 12:38 PM
yea. i dont think they would steer u wrong on the springs.
Old 03-07-2011, 01:13 PM
Rhino's Avatar
As long as it's still 114+4 I'd run it. IMO, for a DD you'll want that advance.
Old 03-07-2011, 02:08 PM
rp0029's Avatar
What about the springs?
Old 03-07-2011, 04:39 PM
I don't understand, according to your original post the lifts are the same?
Old 03-07-2011, 06:08 PM
rp0029's Avatar
Lift is .002 higher than max allowed for ls3 springs.
Old 03-07-2011, 06:38 PM
Fahrenschnell's Avatar
The springs will be fine.
Quick Reply: they sent me the wrong cam... should i just go with it?
