Sponsored by: DashLynx
Headlight switch led
Old 03-09-2011, 11:03 AM
APG12's Avatar
Default Headlight switch led
If I solder a 3mm led in the headlight switch, do I need to attach a resistor? I tried touching the led leads to the switch contacts(without a resistor), just to see if it would work, and I guess that was a bad idea since the led blew up and burnt out when it made contact.
Old 03-09-2011, 12:29 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Yes, you must use a resistor.
Old 03-09-2011, 12:38 PM
APG12's Avatar
Ok thanks. So the resistor gets soldered between the positive lead of the led and the positive contact on the switch assembly?
Old 03-09-2011, 12:40 PM
APG12's Avatar
Also, when dealing with leds, how do you know when you need a resistor and when you don't? I swapped to blue leds in the odometer and didn't need resistors, but I guess they were in the board already, right?
Old 03-09-2011, 01:06 PM
safemode's Avatar
You know when based on what voltage the LED happened to be. They're all definitely not 12V led's since 12v LED's dont really exist. usually the voltage is less than half that. So you get a resistor (depending on current draw too) that will drop the voltage to what the LED wants.
R = V/I (where R is the resistance you need and V is the difference in voltage of 12 and LED nominal voltage and I is current that the LED uses)
Lets take a white 3mm LED from superled's.
it has a nominal voltage of 3.4V.
it has a continuous current draw of 25mA.
so, the resistor we need can be any tiny resistor, since the current wont cause much heat (1/4 watt should work fine)
Now the value it must have is defined by (12-3.4)/ .025
or 344 Ohms
It's normal to put it on the positive side,but it really doesn't matter.
EDIT: Also, give yourself room for charging voltage (driving voltage is usually around 14 or so) if you use nominal values for the LED, you should be fine. Dont use max specs when determining the resistor unless you're using max voltage (maybe 15 would be safe there). or you could damage the LED.
Old 03-09-2011, 01:12 PM
MeentSS02's Avatar
It doesn't matter which side of the LED you solder the resistor to...it will work the same either way.
As for when you need one vs. when you don't, it depends on the characteristics of the LED itself. The reason why I'm guessing you burned out the LED you tried to use is because it was rated for 3.3V, and you applied 12V - that's why you need the resistor for that one. The bulbs you ordered as replacements for your gauge cluster were already rated for 12V input voltage, meaning they were already configured to accept that without the need for additional resistors (this is typical for LEDs that are drop-in replacements for standard incandescent bulbs).
Old 03-09-2011, 01:20 PM
FNSlow's Avatar
^they got it
Old 03-09-2011, 01:21 PM
APG12's Avatar
Ok, I think I got it. Thanks for the info guys!!
Old 03-09-2011, 04:36 PM
Sommer86's Avatar
I've got an '01 Camaro, and all we need to do is swap a bulb. Is this not the case for you T/A guys?
Here are some of my pics from the bulb install.
Here you can see the grey bulb installed. It took maybe 6-7 minutes to tear it all apart, install the bulb and rebuild it. Tuns out it doesn't need to be torn apart, lol. It's a 1 minute job.... just pop the bulb out, insert the LED and DONE!
Old 03-09-2011, 04:53 PM
green28's Avatar
You're not the only one Sommer86, I took mine all the way apart and then realized I was doing more work than I had too.
I've always wondered why the TA's had to do more work to replace theirs as well.
Old 03-09-2011, 06:34 PM
MeentSS02's Avatar
What I've found is that replacement is NOT a good solution to this problem...you are replacing a 360* light pattern with one that is very directional. While that is not a huge issue with most of the interior lights, it is with this one...if you don't get uniform light dispersion, the waveguide (the clear plastic piece) can't do its job, and you'll end up with hot spots and areas that also have no light. They actually make LEDs with phosphorescent coatings that have 360* beam patterns instead of the 30-60* pattern that is more common with LEDs, and is really what should be used in this application (not the surface mount LED shown above).
The problem in this case is you are working around a design that was done when incandescent lighting was the only option, hence the waveguides being the way they are.
Old 03-09-2011, 08:08 PM
APG12's Avatar
The TA switch is pretty much the same. I actually have a TA switch assembly with a camaro ****, dimmer and overlay. I bought one of those bulbs from superbrightleds but it wouldn't fit properly and I lost it when I was trying to trim it down a bit. So I figured id just solder a 3mm led on.
Old 03-09-2011, 08:09 PM
APG12's Avatar
And yea you don't have to take anything apart, just a half turn counter clockwise and the bulb comes right out.
Old 01-16-2012, 08:38 PM
cajunss's Avatar
I'm about to do this to my 2001 Camaro. Does the switch just pop out are do you have to remove anything to get to it?
Old 01-16-2012, 08:54 PM
enigmah's Avatar
Use a sanding wheel to sand down the top "bowl" or "focus point" of the led. Basically grind it flat. Disperses the light in way more directions if you want too take it to a point.
Quick Reply: Headlight switch led
