ls2 into a 2002 assesories drive help
Old 03-13-2011, 10:06 AM
crankstart's Avatar
Default ls2 into a 2002 assesories drive help
I'm currently swapping a 2004 6.0 with an ls2 intake into my 2002 s10 2 wheel drive and i'm having problems figuring out my drive brackets. I tried truck brackets and they wont clear the throttle body and the f body alternator bracket is too low. So will the f- body powersteering bracket and pump work with with a top mount alt bracket? I also notched the frame for ac clearence and the truck pump doesn't clear, does the f body? Thanks in advance!
Old 03-13-2011, 10:19 AM
themachasy's Avatar
Truck intake with truck accessories is the easy way to go, you should have enough height, I did in my s10 (1st gen). Otherwise take a look at the ctsv setup GMPP has, you could probably use some of that.
Old 03-13-2011, 01:48 PM
SUPERBOOST's Avatar
Dont try to mix and truck and car accessories,use one or the other.Truck stuff will probably be your best bet in the s10,especially if the fbody alt. bracket wont clear.
Old 03-20-2011, 08:57 AM
crankstart's Avatar
i mocked up a f body water pump and power steering pump and they look great now i need to find out if i need the alt. and ps in one mount or the passenger side alt mount. Any one done either of these?
Old 06-26-2011, 11:39 PM
1bigoldman's Avatar
Try Current Performance. They seem to do a bunch of these swaps. www.currentperformance.com
Have you tried the Corvette accessories? The PS pump is located like the F-body with the alt mounted above it.
Good luck!
Dhamen
Quick Reply: ls2 into a 2002 assesories drive help
