wheel stud question
Old 03-14-2011, 12:56 PM
608kZ28's Avatar
Default wheel stud question
how far should the stud stick out past the lug nut?
the tracks i race at are both IHRA and NHRA tracks
i wanted to trim some off for when i have my 16 inch rims on
Old 03-14-2011, 02:22 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
From the 2009 rule book
Thread engagement on the lug must be equivalent to or greater than the diameter of the stud or bolt. Length of the stud/bolt doesn't determine permissability (example: a 7/16 inch stud must be thoroughly engaged through the threads in the hex portion of the lug a minimum of 7/16 inch.
https://ls1tech.com/forums/drag-raci...rness-etc.html
Old 03-14-2011, 03:51 PM
608kZ28's Avatar
Originally Posted by Z28/2002
i came across that sticky 10 minutes after i posted my question.
thanks though
