97' LT1 Camaro running lean on bank A & B
my 97 Z28 Camaro is throwing lean codes on both banks does anyone know what the source of this problem could be? Any help is appreciated.
most likely it is unmetered air getting in to the engine after the MAF. Get some starting fluid and spray it around underhood with the engine idling. If the idle raises up, than there is a leak somewhere allowing the engine to pull in outside air and the starting fluid.
