LTX/Callies Question
Old 03-15-2011, 11:23 AM
REAPER13's Avatar
Default LTX/Callies Question
I was wondering why do some call an LT1/4 engine an LTX. I understand why the LSX is called an LSX, but never really understood the LTX thing. I am just wondering because if it is the bigger cubes or the larger bore or stroke then I guess I have had an LTX all this time. I have a 383 LT1 that I will soon be redoing for a twin turbo build.
So that leads me to my next question. I am planning this turbo build and I need to build the bottom end to handle up to 1000rwhp (will be more around 700-800rwhp street) and I have planned on a Callies Magnum crank, Oliver Rods, and JE or Ross custom pistons. I was then told the Compstar products will hold 1000rwhp with no problem. I was under the assumption that 900hp or so is the Compstar limit. I am hoping someone can clear this up for me. Because I am currently running the Compstar Speed Pack and if all I need is new pistons then I can do more things for the car else where.
Old 03-15-2011, 11:52 AM
quik95lt1's Avatar
im not making anywhere near 1000hp but i am running that same shorblock u just described........callies magnum, oliver billets and JE/SRP pistons.......also i run billet main caps........i've been revving the **** out of it over 8000rpm and make prob mid 600 to 700 hp at the fly.......id say spend the money and run the olivers......you get what you pay for
Old 03-15-2011, 03:35 PM
RamAir95TA's Avatar
Since the LT1 and LT4 engines are pretty much identical, use the term LTX when speaking about both. It's just a name - no big deal.
Old 03-15-2011, 04:39 PM
AChotrod's Avatar
Yeah just a name that lumps all LTs together.
Id say your good to go with that Compstar crank. Hell even Eagle forged cranks are rated to 1000hp and 700+ on their H-beams.
REAPER13's Avatar
I have seen your beast before on the forums. Very nice ride and awesome times and numbers.
Old 03-15-2011, 04:46 PM
REAPER13's Avatar
Thanks that sums it up for me. I just see alot of people using the name more frequently.
AChotrod
I may stick with my crank and buy some new rods and pistons. I will never use eagle products, too many horror stories including one of my own. But I appreciate the suggestion.
Old 03-15-2011, 05:05 PM
AChotrod's Avatar
I hear ya but they are rated that high. I know the Eagle cast stuff is garbage but havent seen many failures in their forged cranks
Old 03-15-2011, 05:09 PM
myltwon's Avatar
the "x" in LSX and LTX is simply just a variable meaning that it is a group term used for a family of engines.
Old 03-15-2011, 06:52 PM
Wicked94Z's Avatar
hp doesn't kill rods, rpm does.
Old 03-15-2011, 10:16 PM
05HD's Avatar
It isn't the power it is how it is applied and how smooth it runs. If you whack a cheap bottom end with a 500 hit all at once for example, it may twist up or fold up some rods or whatnot. Turbos are generally very smooth and parts friendly unless you have some bad limiter cutting and reinstating power like a light switch.
Just build it to take the RPM range where the turbos will be happy and pay the most attention to the combustion chambers (including piston tops), rings, head gaskets and exhaust valves. Get these things and the tune right and a turbo mill is the gift that just keeps on giving.
Old 03-15-2011, 10:23 PM
quik95lt1's Avatar
Thanks!!!
exactly!!!! ^^ what he said!!!
Old 03-15-2011, 10:39 PM
gregrob's Avatar
Spray it
Old 03-16-2011, 01:30 PM
REAPER13's Avatar
Heads will be either AFR 210's or 227's. They will be the competition versions. I will also be running a solid roller set up and I have yet to decide if I want to keep a auto or go with a manual. I am planning on having Jim at Speed Inc. tune the car.
Old 03-16-2011, 01:57 PM
AChotrod's Avatar
Jim will get your car running tip top!!!!!
Quick Reply: LTX/Callies Question
