68 camaro throttle cable (carb)
What did you guys use for the conversion of the accelerator rod to the cable type? Pedal, and cable? Ive read everything from a 1st gen 6 cyl pedal to a 70 and up nova v-8, to fabbing up stuff w a lokar cable. Im looking for a good factory type and easy fit. Pics would be awesome as well. Thanks in advance. Oh yeah, its an lq4 carb'd.
I used this!
http://www.restorationperformance.co...r-Pedal/Detail
I also used th lokar ls1 throttle cable,google it
6 cylinder pedal setup. I was able to use a LS throttle cable with it. No Lokar had their TV on my old 200-4r. I think the stock stuff is better. I was able to cut the end off a stock cable and tie it into the pedal. Cost $0 since I had the cable.
