IF STOCK CAMARO RIMS ARE 8.5.. WILL I NEED A WHEEL SPACER FOR SOME CORVETTE 9.5s?
IM GOING FROM 8.5 - 9.5.. WILL I NEED A WHEEL SPACER? WHAT SIZE TIRES DO U RECOMEND FOR A 18 by 9.5IN RIM?
It depends on the offset of your new rims. If the width is 9.5 your offset needs to be a minimum of +38mm i think. Maximum recommended width is 275mm but some guys run a 305 to a 315 nitto 555r DRs cause they run a little narrow but again, that is NOT recommended by LS1Tech. Again, it will depend on the offset but if the rims you are getting are fitted for the Corvette, you should be fine. Personally, I have put 295s on my 18x9.5s with great results.
