Ls1 brakes
I didn't do an alignment after I swapped. I also haven't done one after installing the bmr springs. If you're only street driving or drag racing I wouldn't worry about it throwing off the alignment too much. If you're auto X'ing or road racing it's a different story but for the majority of people you will be fine without it.
IT does need an alignment for sure. The specs for them are different from 93-97 to 98-02 becasuse of the spindles being larger and the rack n pinion is longer on the ls1.
You will need a alignment for sure. Dont skimp out on that at all. Even just a toe n go will suffice
