How to tell if my cats are gutted?
I have a 2002 WS6. Ever since I bought my car people have asked if I have an aftermarket exhaust because it is pretty darn loud. I backed the car up some ramps to take a look under and it seems to be a stock exhaust to me. There are no logos or markings anywhere on the mufflers and the only thing that is stainless are the tips. I looked at the cats and each one of them has an X marked on it with either paint or a marker of some sort.
So now I am wondering if the cats are gutted (or bad), not sure if there is a way for me to easily tell. Any advice?
Also, if I were to upgrade the exhaust at this point should I replace the cats as well? I'm guessing the previous owner wanted a louder exhaust tone without buying a new exhaust.
You're going to get mixed opinions on weather or not to run cats. If you're looking for all out loud and emissions aren't too strict, go without cats (ORY). Just know your car will likely have the race car smell to it with that setup. Personally, I prefer exhaust systems with high flow cats. They don't really hinder performance and there is normally minimal rasp. That's what I'll be going with on my car.
Check out www.LS1sounds.com if you haven't already.
LS1Tech Administrator
Received 1,794 Likes
You mentioned "mufflers". If you have more than one muffler, that is definitely not stock.
As for the unfiltered smell, well that just doesn't bother me personally. Then again, I'm also the kind of guy that drives around an old, stinky muscle car with a 4-barrel toilet bowl, so I'm used to it.
1 Post
Ahh, u must have not seen my thread in the general maintenece/repair section Actually it was running really good when i would smell that, for ~ 2 years (long as i've had the car)
Thanks for the responses everyone! I do believe they are gutted because I sometimes do smell an exhaust/sulfer smell in the cabin. It's not too strong so I don't mind it so much. I only have 1 muffler and I am assuming this is stock:
That is definitely NOT a stock muffler. It looks similar to a Flowmaster 80-series replacement muffler, though it doesn't have the seam down the middle so it's probably a different brand.
Either way, I'm 100% certain it's not stock (stock muffler is much larger and shaped a bit differently). This explains why it sounds so loud.
