Dyno Results AFR Heads Unlocked A4
Old 03-27-2011, 10:55 PM
1989GTA's Avatar
Default Dyno Results AFR Heads Unlocked A4
Here are the latest dyno results from my car. It has a 4L60E and the converter was unlocked. AFR 195 heads, 233/233 Mike Jones Camshaft, Dyno Don short tube headers and my own custom cold air intake. What is that picture on the right. That does not look like an LS1 engine. Hey, it looks like a 3rd Gen Trans Am with an after market TPI system but with a factory plenum. The car is California smog legal and was dyno'd with the catalytic converters, and all smog equipment in place and working.
Attached Thumbnails Dyno Results AFR Heads Unlocked A4-dyno-32611-run-24.jpg   Dyno Results AFR Heads Unlocked A4-engine-bay-32711.jpg
Old 03-27-2011, 11:48 PM
Turd Gen Guy
1nasty86's Avatar
nice hp for sure!
Old 03-28-2011, 12:36 AM
T.Man's Avatar
Quite a bit of porting on the plenum/runners, no? My old L98 motor died hard after 5100ish.
Nice results!
Old 03-28-2011, 12:48 AM
Pwebbz28's Avatar
I am very impressed with how high you got the TPI to carry power. I bet those siamiesed runners and the base are hogged out nicely
Old 03-28-2011, 01:35 AM
jsteele90's Avatar
very nice!
Old 03-28-2011, 04:23 AM
Tobias05's Avatar
very impressive!
+1 for going against the grain.
Old 03-28-2011, 09:42 AM
1989GTA's Avatar
"I bet those siamiesed runners and the base are hogged out nicely"
Yes they are. However the CSA where the manifold meets the head is only 2.2CSA which I feel is holding me back in the upper horsepower range. I have another ported intake system under construction with a 2.61CSA at that point which better matches the AFR 195 heads.
Plus the cross sectional area will be larger all the way through and the runners will be longer in order to pick up the 2nd and 3rd harmonic waves. IMHO these siamesed runners are a little to short with the total around 13.7" from the back of the intake valve.
Old 03-28-2011, 08:35 PM
SAPS's Avatar
TQ seems high for an unlocked verter.
Old 03-28-2011, 09:11 PM
LilJayV10's Avatar
I would have to look at it again but that's what those engines do is make killer torque.
I have a set of Dyno Don headers. They are very nice.
Love to see the 3rd gen!
Old 03-28-2011, 10:19 PM
1989GTA's Avatar
"TQ seems high for an unlocked verter"
Yes, the mid range numbers were surprising. However I am running exhaust expansion chambers. These simulate an open exhaust system. PipeMax was used in the design of the collectors and I would have to say the scavenging effect of the exhaust during the overlap period is pretty close to spot on going by the results. Thank You Larry Meaux and PipeMax. I used David Vizard's criteria on how to build the exhaust expansion chambers and I have to say that works.
The car will be at the Los Angeles Invasion again this year. So we will be able to compare the dyno numbers with the track times. I am hoping for around an 11.5 in the quarter mile.
Old 03-29-2011, 08:49 AM
87silverbullet's Avatar
What cubes are you running under this set-up?
Old 03-29-2011, 01:17 PM
Flow Wizard
Tony Mamo @ AFR's Avatar
Congrats on the results and congrats on finally getting it done!
I know this project has been in the works for many years.....seems like three years ago or so when you purchased the heads from us!
Btw guys the 195 Comp package head would make alot of torque....its a high airspeed design with a conservatively sized runner that still has sizable peak numbers as well (300+ CFM).
Cheers,
Tony
Old 03-29-2011, 03:29 PM
1989GTA's Avatar
Thanks Tony. Maybe it was 3 years ago.
Running 368 cubes. I am in the process of fixing the runner CSA problem. I am just now taking a break from grinding out the welds on my new long tube runner setup. Sometime after the Los Angeles Invasion I will install the new intake then off to the dyno again.
Old 03-29-2011, 05:41 PM
Pwebbz28's Avatar
Pics of the runners? Did u use a stock set of 91-92 cast runners?
Old 03-29-2011, 06:48 PM
1989GTA's Avatar
No, they are modified SLP runners. See if I can find a picture and post it. OK, here are some older ones but they will work. I have had the interior ceramic coated with a heat barrier since then and a little more clean up.
Attached Thumbnails Dyno Results AFR Heads Unlocked A4-slp-first-runner-done-002.jpg   Dyno Results AFR Heads Unlocked A4-slp-first-runner-done-003.jpg   Dyno Results AFR Heads Unlocked A4-slp-first-runner-done-004.jpg   Dyno Results AFR Heads Unlocked A4-slp-first-runner-done-005.jpg
Old 03-29-2011, 07:15 PM
ULTIMATEORANGESS's Avatar
Smile
im guessing that drop off is due to a restriction somewhere?
you probably explained it and i missed it lol.
Old 03-29-2011, 07:55 PM
Pwebbz28's Avatar
Got any links to your project? I've been messing with TPIs for nearly 2 decades. Love them.
Old 03-29-2011, 08:16 PM
1989GTA's Avatar
Yes, I think the "restriction" if you want to call it that is in the intake manifold itself. It has a CSA of 2.2 square inches where it meets the head and was designed for my previous motor. It should be up around 2.61 square inches for this motor with the AFR heads. If I rework this intake I will open the intake port to the head to 2.61" and the exit from the runner to the intake to 2" in diameter. That would get it done.
I have a thread going on thirdgen.org if you want to follow along. I think you have to sign in to see the pictures. Here is the link.
http://www.thirdgen.org/techboard/tp...be-runner.html
Old 03-29-2011, 08:19 PM
Pwebbz28's Avatar
Thanks. Been a member of TGO for a pong time but ever since I parked the 92 I haven't been on there much.
Old 03-29-2011, 08:20 PM
Marc 85Z28's Avatar
The torque is a characteristic of a design he eliminated
I'm having a hard time believing a 368 with 195cc heads, a mild cam, shorty headers with cats, and a modified TPI (albeit well thought out) intake is making that power through an unlocked converter in a 4L60E.
Actually, I'm having a VERY hard time...
Quick Reply: Dyno Results AFR Heads Unlocked A4
