Any special
Any special
tools needed to swap out injectors on an LS1? Sorry if this is the wrong section for this question. I'm going to be installing mine this weekend and didn't want to run into any issues.
Thanks.
Thanks.
Kleeborp the Moderator™
Not really...just need to unbolt the fuel rail from the intake manifold. You can probably even leave the feed line attached, but make sure you relieve any pressure still in the rails with the Schrader valve. As long as you don't mind getting fuel stank on you, it is pretty straightforward.
