Anyone ever do a TR224 to TSP231/237 swap...
Old 02-18-2004, 10:42 PM
Mike00FRC's Avatar
Default Anyone ever do a TR224 to TSP231/237 swap...
Looking for anyone who has had the TR224(pref. 112lsa) and swapped in a TSP 231/237 cam with before/after dynos, without any other changes... not counting springs, ect.
I know the TSP should make more in the top end, but I would like to see how much is lost from the lower RPMS. I did an overlay of the 224 and the T-Rex camshaft. Both were pretty much the same setups AFIK, with the exception of one having a fordged bottom end, but that shouldnt make any difference. I would like to do the same comparison with the 231/237. The 'rex is a little too big and lost too much in the lower rpm range for my tastes.
Thanks,
Mike
Old 02-19-2004, 12:00 AM
abate1224's Avatar
i'll be able to tell you in about a week. i am doing the switch next week!
Old 02-19-2004, 02:37 AM
Restricted User
CAT3's Avatar
Sorry no Dynos, only track times. I have run one pass quicker with the TSP cam, 12.35 to a 12.42 on a TR 224 cam. All other runs have been matched by the TR 224 cam, even the Nitrous runs. I think the tune is close enough, the AFR was same and timing was utilized. With stock heads, I dont see much happening. But, oddly enough on the street I can pull my friends (Drew778) SS and he has run a few tenths quicker than me.
Old 02-19-2004, 09:36 AM
Josh's Avatar
I'd like to know this as well, as I'm considering the same upgrade.
Josh
Old 02-19-2004, 09:51 AM
CamaroCain's Avatar
A local customer swapped from the 224R to our 231/237 in his '98 SS A4 with stock cylinder heads and LS1 intake manifold, and he picked up 17 RWHP.
https://ls1tech.com/forums/generation-iii-internal-engine/115813-another-231-237-install-results.html
https://ls1tech.com/forums/generation-iii-internal-engine/91133-gained-15-rwhp-over-mti-c2-tsp-231-237-a.html
Old 02-19-2004, 11:33 AM
1fastWS6's Avatar
I'm in the same boat here too. Considering the TSP cam or something similar.
