700r4 troubles
700r4 troubles
Hello all, 2 days ago I was driving around my jeep it has a 6.2td and a 4x4 700r4. It was driving fine before that day. Then it started to bounce in n out of 4th gear on the freeway. And when I got home the tv cable was disconnected and not adjusted so I connected it and adjusted it and now it has trouble shifting into 2nd and does not want to shift into 4th. And this morning I changed out the fluid and filter and no change. Did it burn up or is there more trouble shooting I can do?
the 700r4 in my K5 shot craps today too it completly blew 3rd and OD out of no where its always been rock soild till today. im gonna rebuild it and sell the truck
The band burns up first when there is a problem with the tv. The tv controls pressure for the tranny. The band in ur 700 is burnt. The band is applied in 2nd and 4th. I am 99% sure this is ur problem!
Yea the trans is shot today I was driving around for 80miles or so and when I was coming home it was in overdrive and it began to slip like if it were losing fluid. And when I stopped with the engine on to check the fluid and it was perfect when I get back on the highway it shifts 2and 3 good and all of a sudden no od what so ever! And another question my trans guy has the lock up set up to where it used just one wire in the plug is that ok or is can there be a problem there?
