Can I Fit These Wheels & Tires?
Old 04-10-2011, 06:36 PM
sgarrett's Avatar
Default Can I Fit These Wheels & Tires?
If I were to lower my 01' camaro 1.2" with Strano Springs/Koni Shocks (http://www.stranoparts.com/partdetai...D=90&ModelID=7) and throw on 18x9.5 c5 zo6 replica wheels all around, +56mm offset, with 275/35/18 tires, would I need to do the BFH mod to fit these wheels & tires?
Please post, especially if you have the same setup!
P.S. I have a non adjustable Spohn panhard bar if that would do anything
Old 04-10-2011, 08:33 PM
Xsta Z 28's Avatar
Nothing needed to be done . . the offset, tire and wheel width is all within OEM Camaro SS wheels so you will be fine.
Old 04-10-2011, 09:19 PM
sgarrett's Avatar
Even with a 1.2" drop?
Old 04-10-2011, 11:06 PM
carlos64030's Avatar
A 1.2 inch drop really isn't that much, bro.
Old 04-10-2011, 11:09 PM
LaBLKv6Z's Avatar
Running that wheel and tire combo and lower than that, no problems.
Old 04-11-2011, 12:32 AM
sgarrett's Avatar
sweet, thanks all!
Old 04-11-2011, 12:38 AM
ANTICOP RAM AIR's Avatar
im lowered a little on 295 35s with c5 skinnies, same offset and I had to do a little clearance mod...You will ride no problems..
