M6 Swap help...
Old 04-11-2011, 03:33 PM
zac50's Avatar
Default M6 Swap help...
i was thinking about doing the m6 swap to my a4 and needed some help on what i would need... how much it would cost... or if it would even be worth it! i dont plan on racing or anything like that i just like the feel of driving an m6 over an a4...
Thanks guys,
Zac
Old 04-11-2011, 04:00 PM
Sargeant Sh!tbag's Avatar
Its not worth it unless you can find someone with an M6 that just wants an auto you could swap with.
Rough numbers here
Used t56 ~$1800
Clutch/flywheel ~$450
Slave cyl ~$150
Master Cyl ~$120
Pilot Bearing ~$20
Shifter ~$150
Fluid for Trans ~ $40
Pedal Assy/brackets/interior BS $??
Im sure some things are missing here.
Old 04-11-2011, 05:09 PM
zac50's Avatar
thanks man, maybe ill luck up and find someone who wants to trade...
Old 04-11-2011, 06:00 PM
therealcreeper's Avatar
$1800 for a used stock transmission? and $40 for fluid? ummm no.
-rebuilt/upgraded t56 from TDP $1900 ($700-1000 for working used unit)
-bellhousing $100-150
-clutch kit (pp/disc/flywheel/slave/pilot) $700ish for a really nice TDP unit
-master cylinder $120
-crossmember/pedals/torque arm mount/console $2-300 from partout
-trans fluid $12
-brake fluid $8
-wiring/electrical goodies $30
-m6 tune flash $75ish
I did the swap about 6 months ago. Is it worth it? it depends. I plan on keeping my car for a while. 4l60e's start to go between 100-120k more often than I like knowing about so it came down to either $3k for a built 4l60e and converter or a 6 speed swap. I like road racing so I went the 6 speed route. I now have a transmission that holds more power and does what I like it to do.
I'd say for a car that doesn't get raced it's really not worth it. Just sell it and buy something stick unless it has sentimental value or you have a lot of time/money in it already.
Old 04-11-2011, 06:54 PM
-trans fluid $12
-brake fluid $8
Do it right or dont do it.
Price on trans included being gone through/upgraded.. Ya, you can get a nice super low mile stock trans for ~ 1200..
$12 for 4 qts of good trans fluid. . This is the cheapest dime store build I.........................
NVMND, Im sure this guy is on it. Good luck with the swap man. You should PM creeper for full details.
Old 04-11-2011, 07:39 PM
Empatho's Avatar
I paid $1550 for a GTO 6 speed complete with sensors and bellhousing shipped, and it had less then 30k miles. If you really wanna do the swap you can start looking at the for sale section for all the parts that you will need, and if you are really patient you will find allot of awesome deals. After all is said and done the swap will end up costing you around the same price of a built 4l60E with a good converter.
Old 04-11-2011, 08:20 PM
the_merv's Avatar
I did the swap a while back..
$1200- T56 Trans, used, with Bell Housing. I re-built it with the Tick Stage 2 Kit and other parts that it needed..so about another $1k in it.
$1000- Textralia Clutch Kit
$150 - New Slave Cyl.
$200 - B&M Ripper Shifter
$35 - 2" White Ball with 6spd pattern..
$75 - LPP Speed Bleeder..I wont install one without it.
$170- Stock Master Cyl, new.
$40 - Pedals
$30- M6 Cross Member, then I upgraded to a Torque Arm Relocation Crossmember from UMI
Pilot Bushing was free, so was the Rubber Boot and Tune cause I have HP Tuners. 6 Spd Console Piece I made from the 5spd one in the V6 Car I swapped..
Ya there's about $4k there..just short of it. I kept it all from my Camaro and stuffed it in my MCSS..works like a champ..
Old 04-11-2011, 08:30 PM
ringmaster72's Avatar
Thanks guys,
Zac
Only you know if it is worth it. I would gladly bite the bullet to have the m6. You might just have to look around to find a good deal. Maybe you will be able to sell ur auto to recoup some of the costs.
Old 04-11-2011, 09:31 PM
zac50's Avatar
well i love my car and i have already put wheels and tires on it and i have painted it so it kinda has sentimental value to me and i dont really want to risk selling it and not be able to find an M6... i just needed some help on what all i would need to have so maybe i can start working toward getting it done....
Old 04-11-2011, 09:45 PM
zac50's Avatar
http://http://cgi.ebay.com/ebaymotor...item1c1ad10068
i found this on ebay, it a "rebuilt" t56 for a starting price of $1575 but there are no bids on it yet....
Old 04-11-2011, 09:48 PM
zac50's Avatar
i dunno if a t56 out of a vette will work but this one is $975 and has 30k on it....
http://http://cgi.ebay.com/ebaymotor...362+&viewitem=
Old 04-11-2011, 09:53 PM
1999Z28's Avatar
just wait and find a wrecked fbody. That's what I did. Found a 89k mile 00 SS for 5000....got it for 3500. Took the tranny, wiring, pedals, and all. Turned around and sold it for 3500 lol. Still spent another 3k on clutch, driveshaft, master, slave, UMI crossmember and so forth. But made the swap really easy.
Old 04-11-2011, 10:02 PM
Circa307's Avatar
search in the stickies if you do decide to do it. help me out alot.
Old 04-11-2011, 10:09 PM
the_merv's Avatar
Na you will have to add parts to it..pretty much all that is useable is the internals & case.
Old 04-12-2011, 07:42 AM
what's your problem? you said nothing about rebuilding the transmission, you just said used t56. and I'm sorry not overpaying for fluid is considered "dime store" in your mind. 4 quarts of pennzoil ATF is $14, Coastal (which I believe TDP uses) costs $12 for 4 quarts, and there are plenty of others out there in the same range that work just as well as anything else. I tried the ~$40 synchromesh for a while, liked it at first, but cold weather shifting was awful and noticed no difference at all switching back to ATF.
Old 04-12-2011, 09:23 AM
zac50's Avatar
thanks for the help guys! ill see what i can do
Quick Reply: M6 Swap help...
