LS2 theoretical question
supposedly the LS2 is gonna come with an improved exhaust manifold/cat set up that would
1) eliminate the A.I.R. system by having higher-flow cats moved closer to the manifold. WOOT!
2) redesigned manifold for better flow as well as thinner wall (4cm to 3cm).
u guys think this would work for our measley LS1's? i just want a street legal, better (not best) flowing exhaust. i think this may be my perfect set-up!
block should still be the same bore centres.
The question will be are you using them in a C5. And also whether they keep the same exhaust bolt pattern & port location. I don't see C6 stuff fitting an f-body or much else, and who knows what they're doing with the exhaust on the 2. :dunno:
Originally Posted by greekss
good question... but isnt it a comopletly diff. block ?
and increased the compression ratio from 10.1:1 to 10.9:1,
and raised the redline from 6000 to 6500, put a greater lift cam,
and put freer flowing 90mm intake.
awsome engine
