Need help with programming for ecu (converssion)
Old 04-13-2011, 07:19 PM
balls51's Avatar
Default Need help with programming for ecu (converssion)
i just did a conversion on my 97 ws6 trans am.
had 4l60e and 323 rear now has t56 6spd 342 rear
went to reprogram through gm and I cant. They have to use my vin to get the programming. And it would be the same as i have now. So i either have to buy an ecu with the same specs as whats in the car now or get a vin from a 1997 with the same specs and use that to get the tune. Can anyone help me out.
Either need a ecu or a vin
needs to be t56/3.42/lt1
Old 04-13-2011, 07:37 PM
Ocala93TA's Avatar
Why would you need to program the ecu ? Your the one shifting gears . Maybe Iam wrong ? I could see needing the change for the gears but not because of tranny . I used pcmforless to program my ecu they are great !
Old 04-13-2011, 08:57 PM
balls51's Avatar
Default ecu
it wil run but it will throw codes and speddo will be off
Quick Reply: Need help with programming for ecu (converssion)
