drift car kouki s14 / LS1 / G-force GSR
Hi guys , my name is Pierre-Olivier and im from Canada
last year i started a build to go into drift competition !!! back then i was running a RB26dett (inline 6 twin turbo from a Skyline GTR)
this is how my car was looking 3 year ago with the first engine
1000 miles later it blew ... the engine sized
so i decided to put a new one in the car went all out and forged it !!! the firts one only had pistons in it !!!
it was doing ok for the stock turbo i was running ... went to a couple drift day ... was having a ton of fun ... destroid the car but its all ok , drift car or there for that
here is a vid of my car when it was RB ... just a lil pull
http://youtu.be/NsFarFXR2oY
this winter i had plans to put a mid size single turbo and all the stuff to make it work !!!
but when i opened up the engine to check if everything was ok this is what i found out (all 6 cylinders were the same)
i was so mad that this was my second full forged RB26 that blew ... i decided to part out my engine set-up and go LS1
i sold most of my parts that were on the RB
RB25 Ross Harmonic Balancer (come with rb25 alt and power steering pump) : 500$ SOLD
RB25 Nismo slave cylinder : 100$ SOLD
R33 crank in great shape : 450$ SOLD
Greddy Intake manifold : 500$ SOLD
Innovate XD-16 Standalone Kit Wideband w/ LC-1 and O2 Sensor : 240$ SOLD
DEFI gauges : 450$ SOLD
RB26 oil pan(RWD mod) with TOMEI baffle : 300$ SOLD
RB25 transmission : 500$ SOLD
RB coil pack ground : 20$ SOLD
OIl cooler : 200$ SOLD
ORC twin plate (Push type) : 500$ SOLD
GREX sandwitch plate : 100$ SOLD
N1 water pump : 120$ SOLD
N1 oil pump : 240$ SOLD]
Mishimoto Rad fans : 180$ SOLD
RB26/25 Eagle rods : 400$ SOLD
nismo Thermostat : 40$ SOLD
during the last summer i had one crash that took my front bumper for good ... so i decided to change the look of my car !!!
i went D-max all around
then the season ended and the car went to sleep !
this winter was the time to put a cage and prep the car for the DMCC rules
took the sound deadening out with some dry ice
started the cage and tube front end !!! here are the pics
now for the front end ... here what is going on !!! now that im going V8 there is no intercooler so custom head light bracket will have to be made but that a small thing !!!
so here is the rest of the pics of the cage and chassis work that was done !!!
we did a rear fire wall to ... i dont have a fuel cell right now but it's on the list of mod to do
test fited my dash ... i had to cut abit but it still looking realy good
after the dash ... i decided to cut the inner doors
it was time for the paint ... so i cleaned up all the interior
(that pic is with the hold engine mounts for the RB in s-chassis)
it from a 2003 corvette that had 44*** klm ... i need to find my self a F-body set up for the acc. but that about it !!!
at the same time i contacted SIKKY.com for there swap kit and other parts !!!
1 7/8 headers
since i'm on the east coast of canada and about 1 hour from the border a champlain .... i source a G-Force transmission in NC and it was ship to freeport forwarding ... that way a saved on border fees and shiping
that is how it was ship to me ... realy nice case
that was last week ... monday my engine was send to my engine builder for a clean up and double check to see if everything is ok with the engine !!!
after the engine cleaned this is how it look (those last pic were taken today)
ARP head studs are coming in tomorow so we will be able to finish the engine
1 7/8 headers
this is what it looks like right now !!!
i odered from JEGS yesterdays ...
ATI damper
KRC bleeders
ARP crank bolt
Quarter master tripple plate clutch
my quicktime bellhousing is coming in monday !!! it should be in the car in the next 2 weeks !!!
i cant wait
ATI damper
KRC bleeders
ARP crank bolt
i cant wait
can someone just conform that for me !!!
my friend as a 1998 corvette ... he switch the intaje manifold for a LS6 one ... when it was off is engine ... the part number for is LS1 intake wasnt the same as mine 03 LS1
i decided to compare with is LS6 one and they were the same !!! is it an upgrade the guy i bought the engine from did or its from factory like that ???
like you all know i was in JDM stuff before so i dont know those engine like i knew my RB ...
any input or head's up will be appreciated
Later LS1s had LS6 intakes. I'm pretty sure on F-bodies, they had LS6 intakes in '01 and '02. I'm sure the Corvettes from then on did too on LS1 cars. They're worth 15-20 hp over the old LS1 intakes.
Nice. If you are using that trans and the 5.5" triple disk, why did you get a QuickTime bellhousing? You should have just gotten a reverse mount Quarter Master bellhousing. That is way cleaner than using a flexplate for starter engagement. Looking forward to updates.
Andrew
Andrew
Andrew
Andrew
the quicktime is in order but its not paid yet !!! so i can change my mind
Your trans also doesn't have a bearing retainer snout. If you used a reverse mount Quarter Master bellhousing you can mount the Tri-light TOB to the inside of the bellhousing. I would also count the number of splines on that input shaft. Hopefully you don't have 3 too many...LOL Many of those transmissions have 29 spline input shafts, which is no big deal you just have to order the right disks from Quarter Master.
Also, a 3 disk 5.5" clutch is going to be pretty much an on/off switch. Hopefully you don't have any illusions about driving this thing on the street. If you wanted some level of streetability I would consider going with a 7.25" 2 disk Rally, or if you have deep pockets then get a 3 disk 7.25" carbon/carbon.
Andrew
Protect your legs from what? LOL You are using a 5.5" diameter flywheel and clutch, not a 14" diameter flywheel with a 12" clutch. The need for a blow proof bellhousing comes from the use of big heavy flywheels that can come apart under high RPM use. You don't have those issues with a small diameter clutch.
Andrew
Andrew
yeah the bellhousing was to protect me from the flywheel exploding ... but when i first ordered the bellhousing (Quicktime) i didn't know witch clutch i would be running ...
now that i have that QM tripple plate and that you showed me the reverse Bellhousing ... im pretty sure i will go with that !!!
