LS1 to Powerglide Quick Q
Im swaping a LS1 into my 69 Camaro I need to know if there is any reason I can not use my powerglide torque converter? I already have the GM adapter and bolts.
Thx Eric
Thx Eric
You sure can use it. The converter will not bolt up to you factory flexplate, but you can swap that out for an aftermarket flexplate, such as the TCI and you'll be good to go!
