OD and drive doesnt pull
Ok just did my 12 bolt swap. And went to drive car, it doesn't pull in OD or D. I can pull it down into 2 or 1 and I feel it grab. As i drive it I can manually shift it and all the gears are there including lockup. But when I stop I feel the tranny neutral out again. Any tips or did i accidentally unhook something while under there?
Moderator
The input sprag failure is pretty common when breaking a rear end. I have also seen where the low roller takes a whack as well. Make sure to address these when you have it apart. Vince
