I have Manually shift into 3rd and 4th HELP !!!
Old Jan 31, 2011 | 03:17 PM
djjab57's Avatar
Question I have Manually shift into 3rd and 4th HELP !!!
I have a 94 Camaro LT1, When taking off I have to start in 1st or 2nd. When i get up to speed i can shift it into 3rd and then into 4th. From a dead stop car wont move in OD or D. What is causing this ?
Old Jan 31, 2011 | 03:43 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
https://ls1tech.com/forums/automatic...ear-3-4-a.html
Old Jan 31, 2011 | 03:52 PM
djjab57's Avatar
Thanks ! How hard is it to change the sprag? Do I have to tear it down or take it out?
Old Jan 31, 2011 | 04:41 PM
just posted the link for 'reference',doesn't mean that's your actual problem.
yes,a removal and teardown.
Old Jan 31, 2011 | 09:18 PM
performabuilt's Avatar
LS1Tech Sponsor
Yes removal and tear down with possible rebuild and certainly parts replaced min
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 31, 2011 | 09:20 PM
Vince B's Avatar
Moderator
You have a sprag failure plain and simple. I'm sure if the trans has some miles on it you will have to have a full rebuild. If you need any other advise let me know. Vince
