Will a 1st gen s10 master cyl operate a lsx t56 slave?
Old 04-23-2011, 03:00 PM
boosteds10's Avatar
Default Will a 1st gen s10 master cyl operate a lsx t56 slave?
Will a first gen 2wd s10 clutch master cylinder properly operate a lsx t56 slave cylinder with or without modification?
Old 04-23-2011, 03:40 PM
jmd
jmd's Avatar
Few people will know the following for you without research:
i.d. / piston size of the S10 master cylinder
possible piston travel with that master cylinder
travel of the attachment point on the pedal
if volume of 1 and 2 accomplish the goal of matching the f-body master cylinder volume movement but 3 isn't enough, movement of the attachment point might do it.
Old 04-23-2011, 03:44 PM
boosteds10's Avatar
Where could I find this information without having to tear one apart a measuring it?
Old 04-23-2011, 05:01 PM
jmd
jmd's Avatar
Spend a whole lot more time reading through parts books or parts listings than sleeping until you find it. Then, hope the information is correct.
Or pay someone to do it.
Quick Reply: Will a 1st gen s10 master cyl operate a lsx t56 slave?
