Will a 1st gen s10 master cyl operate a lsx t56 slave?
Will a first gen 2wd s10 clutch master cylinder properly operate a lsx t56 slave cylinder with or without modification?
Few people will know the following for you without research:
i.d. / piston size of the S10 master cylinder
possible piston travel with that master cylinder
travel of the attachment point on the pedal
if volume of 1 and 2 accomplish the goal of matching the f-body master cylinder volume movement but 3 isn't enough, movement of the attachment point might do it.
