Need KarsIII Info for custom subframe connectors
A friend of mine is going to build me a set of sub frame connectors. He works in a mine as a maitanence welder and has access to super high strength aluminum, which he says has more strength than cromoly but the sub frame connectors will only weigh in at mere ounces. An idea I had was to make a Karrs and subframe braces as one unit.
If all goes well even if we don't add the karrs set up, we will be able to make more for people because the jig will already be made.
What I need is Photos of the Karrs kit installed in the car, I already have plenty of pics of the unit itself.
And if someone would want to take measurements that would be cool too. I can provide a pic if you need it, even a hand drawn sketch would do.
A set of the Karrs instructions would even help too.
Thanks.
Thanks.
