What Engine Oil To Use?
Old 02-21-2004, 06:47 PM
TeamA.P.B.21D's Avatar
Default What Engine Oil To Use?
I've been using Mobil 1 Synthetic 5w-30 in my '01 Z28 for three years now. I've been wondering if I should change to a different weight, 5w-30 seems a little thin considering I live in IL and only drive it during the spring, fall, and summer when there's no snow on the ground. In the winter I drive my POS beater, a Plymouth Reliant with over 300K miles on it(It just won't die, it's indestructible!).
Old 02-21-2004, 07:29 PM
Z28Venom's Avatar
Red face
Do a search.. there are hundreds of posts on the subject...
Patman is the resident oil expert.. most of the posts you find will have great info provided by him.
Old 02-22-2004, 08:15 AM
66deuce's Avatar
i switched to 10w-30synthetic(was using 5w-30 dino oil) about two years ago and have had no problems.in fact,my oil consumption dropped quite a bit.
Old 02-22-2004, 08:18 AM
z2802sunsetls1's Avatar
redline 5w30
Old 02-22-2004, 03:11 PM
INMY01TA's Avatar
I use Redline 10w30 cause, well, it's the best. Nothing wrong with Mobil one at all. (I'd use 10w30 for sure though)
Old 02-22-2004, 05:27 PM
crainholio's Avatar
The GM LS1 crate motor installation guide specifies 10W-30 synthetic oil. Kinda interesting what the General likes when CAFE standards aren't involved.
Patman seems to like the German-made variant of Castrol Syntec 0W-30, and so do I now that I'm using it. My '02 Silverado is quieter than it was with Amsoil 5W-30, and the LS1 I just finished swapping into my '82 Z28 is nice 'n quiet also. When I hit the road course this season, I'll be running Mobil Delvac-1 5W-40.
Old 02-22-2004, 10:05 PM
JoSeY's Avatar
ROYAL PURPLE IS THE ONLY OIL I HAD IN MY CAR AND I MADE OVER 440HP ON A MILD TUNE, STAGE 2 MTI HEADS AND AN X1..MY CAR (if the truck driver didn't think it was a parking spot) would still be making this HP @ over 110,000 miles.
Old 02-22-2004, 10:08 PM
6 Second Club Moderator
LASTLS1's Avatar
Go the 10-30. Mobil is good. AMSOIL is best. But go with the 10-30.
Old 02-22-2004, 10:18 PM
JoSeY's Avatar
Amsoil didnt measure up to RP....10-30 is a safe all weather oil...here in Htown...10/40 is a must in the summer....
Old 02-23-2004, 05:22 AM
Patman's Avatar
My top recommendations are German Castrol 0w30, Redline 5w30 or Amsoil 0w30 or 5w30.
Old 02-23-2004, 05:42 AM
Trans Am 2 N V's Avatar
Patman dont you get tired of answering the same question
Do you have a automatic saying everytime you see a oil post, they are always the same
i havent been able to find the German castrol so I run the Redline 5w30
Old 02-23-2004, 01:12 PM
Sonny's Avatar
anyone here uses schaeffer's 7000 blend 10w30?
Old 02-23-2004, 03:45 PM
Patman's Avatar
I was using that in my LT1 last year actually, and also tried their 5w30. I got good results, but have gotten better results since switching to the 0w30 Castrol.
I have seen an LS1 oil analysis running Schaeffer 10w30 though and it looked incredibly good, it had very low engine wear.
