IF you made the decsion on the stock LS1?
IF you had the decision on what the Stock LS1/6 had.
It has to be very reliable and have the same warranty that they come with.
what size engine or what bore and or stroke. what size cam, what heads and what would they flow around.
and also whatever else you feel that would need to be changed. oil pump, timing chain, converter, gears, lid, MAF, throttle body, manifold, push rods etc.....
