Help P/V clearence and push rod length problem!!
I thought about it and did the test again and it was fine. Is this scratch or nik from my valve going to hurt anything??? I looked over the valves and can see nothing, not even where contact was made. I did this again with retesting to be safe one the number 3 cylinder torquing the rockers down as if they were the number 2
I have no excuse for my stupid doings but damn dont ever talk to a hot girl from school while working on you engine!
I will post a pic of the scratch. It looks like nothing I was just worried about my new heads! I better get some *** from this chick now
You should be fine but there is the posibility of a bent valve more so than piston damage. If you torqued the rockers bolt to 22 pounds I doubt you have any damage. That's not a terrible amount of load. If you are concerned you could run a leak down check. If the heads are still off the car then check the valve on a dial indicator.
