PCMCalibrators offer PCM Servicing and Tuning
Our mail order tune pricing specials start at $200 This is for bolt-ons, stock vehicles and start up tunes for most combination.
All we need from you is your PCM and a list of your mods, if any. You can leave a check in the box and shipping info.
All pcm's are returned the same day received 99.9% of the time, and overnight shipping is not a problem if necessary.
PCM/ECM Repairs
We also have dyno proven customized calibrations for any tire size, differential ratio, exhaust or engine modification. Torque management defeated, VATS defeat, Performance engine and transmission tuning. CAGS removed without need for bypass kits. Trouble code disable for custom street rod applications. Speed density tunes, supercharger calibrations, as well as twin turbo
Please feel free to contact me at caleditor@pcmcalibrators.com if you have any questions
PCM/ECM Repairs
We offer PCM/ECM repairs. Have a dead or bricked PCM/ECM we can fix that -- $75 for the standard PCM and 2 day turn around & $125 for ECM and up to 5 business days
PCM/ECM CloningNeed a mirror image of your PCM/ECM in another PCMECM we do that also. Do you have a “Bricked” PCM/ECM and don’t want to purchase additional credits for the new PCM/ECM? This is for you -- $75 for the standard PCM and 2 day turn around & $125 for ECM and up to 5 business days
PCM UnlockingDo you have a PCM/ECM with a “Lock” on it? We have several ways to unlock these units. We can lift the chip. We have a ribbon cable that attaches to the chip on the board and with our software we can unlock the PCM/ECM. We also have software that will seek out the lock and allow us to unlock them, but this may take several days -- $75 for the standard PCM and 2 day turn around & $125 for ECM and up to 5 business days
We also offer Dual-Flash PCM’s that are professionally built -- Email us for details. Programmer@pcmcalibrators.comWe also have dyno proven customized calibrations for any tire size, differential ratio, exhaust or engine modification. Torque management defeated, VATS defeat, Performance engine and transmission tuning. CAGS removed without need for bypass kits. Trouble code disable for custom street rod applications. Speed density tunes, supercharger calibrations, as well as twin turbo
I am located near I77 and Cherry Rd, but 95% of the PCM repairs and all of the Dual Flash work is done in Rockford IL by my business partner. He is a professional electronics engineer technician. He worked for a Tier 1 GM supplier for over 14 years.
We both do the tuning side. Tom mainly uses TunerCat and EFILive and I use HPT, JET's DST and Duramax Diesel Tuner. I have another 7 tuning programs that I also use when needed.
For the summer special we are letting the Dual-Flash PCM's go out the door for $350 + shipping for complete units that will not need additional licensing.
We will convert your PCM for $375
Our mail order tune pricing specials start at $200 + return shipping.
PCM/ECM Repairs
PCM/ECM Repairs
PCM Unlocking
This is the same offer as another sponsor.
If you want a more dialed in "Dyno Proven Tune" they run about $500 and include the following
A customized calibrations for any tire size, differential ratio, exhaust or engine modification. Torque management defeated, VATS defeat, Performance engine and transmission tuning. CAGS removed without need for bypass kits. Trouble code disable for custom street rod applications. Speed density tunes, supercharger calibrations, as well as twin turbo
We have more on order and I am working with the last 40 or so that I have left.
Thanks for all of the support
