2nd Gear Grind
Old 05-02-2011, 10:00 PM
TORCHD 02 TA's Avatar
Question 2nd Gear Grind
I just pulled the car out of storage, and on my first WOT run grinded 2nd gear twice I never grind 2nd gear.. So what gives?
I have a Textralia Z grip with maybe 3,500 miles on it.. My car isn't a DD, jsut a cruiser basically
Any ideas??
Old 05-03-2011, 09:56 AM
Jeremy@RPMTransmissions's Avatar
If the car has been sitting all winter you might try bleeding the clutch. Brake fluid wicks moisture something fierce so it might need to be changed also. Hope this helps.
Old 05-03-2011, 07:36 PM
TDP
TDP's Avatar
If it's a clutch or hydraulic issue, then it will be hard to get into first and reverse. If it's just grinding 2nd gear, then it has to be something internal [2nd gear engagement teeth, slider, and/or ring(s) worn]. It could only be a coincidence as it just happened to start messing up after taking it outta storage. If this is the case, inevitably, you'll need a rebuild/upgrade. Check my sig for rebuild info/website info.
Old 05-03-2011, 07:52 PM
How do I drain all the break fluid and replace it with new stuff?
Old 05-04-2011, 09:42 PM
Blwn_by_Twins's Avatar
Open the bleeder and let it gravity bleed. Just keep the reservoir filled up.
Quick Reply: 2nd Gear Grind
